srspaceman
#1 Posted : Wednesday, May 19, 2010 2:28:29 PM(UTC)
srspaceman
I have a whirlpool Calypso washer that when I attempt to start wash the time will come on but I can not get it to start filling. I was able to do the soak-soil level-soak-soil level diagnostic test once. Afetr that it worked for one cycle. Now i cant get it to work again and i am unable to get the diagnostic test to work again. Any suggestions what it may be?
Thank you.
sidfink43
#2 Posted : Friday, May 21, 2010 3:04:42 PM(UTC)
sidfink43
This suggests a problem with the main control board, or possibly the touchpad but you are going to have to change them out to check it out.
Here is a service manual that should help you with diagnosis.
https://secured.whirlpoo...4632a4/$FILE/8178010.pdf
srspaceman
#3 Posted : Saturday, May 22, 2010 6:41:50 AM(UTC)
srspaceman
Thank you.
Drain pump motor on whirlpool calypso washer (Washer Repair)
by mike0123 4/9/2011 7:17:34 AM(UTC)
Whirlpool Calypso Washer (Dishwasher Repair)
by indy4300 8/25/2010 1:02:28 PM(UTC)
Intermitent LF on whirlpool Calypso Washer (Washer Repair)
by troubledinTX 1/16/2010 12:43:05 PM(UTC)
Whirlpool Calypso Washer - There is power, but does not respond to any commands (Washer Repair)
by dtdiep 8/1/2008 11:48:39 AM(UTC)
