Dan Thomas
#1 Posted : Friday, July 4, 2008 1:15:57 PM(UTC)
Dan Thomas
I have a Kenmore washer that my tenants left at the house when they left. I would like to let the next tenants use it if it were working properly.
The problem is after the wash cycle is finished it doesn't go into the spin so that it can go on to the next cycle - rinse. No matter which spin cycle I manually put it in it won't respond. I finally gave up on it yesterday and when I went there this morning the water was out and the complete washing cycle had been completed. So I guess my question is : Is there a pause or delay that would make that happen or what is broken that would make that happen? What do I do about it?
Thank you in advance for any help you can give me.
The only numbers I found on the machine were : SM9710804-A
Parts#: 3953325
Help With Kenmore Washer (Washer Repair)
by akovacic 1/20/2013 5:46:17 PM(UTC)
Help with Kenmore washer (Washer Repair)
by AvionTech 12/6/2008 6:46:19 AM(UTC)
