bobby barron
#1 Posted : Monday, May 17, 2010 7:44:37 PM(UTC)
bobby barron
My freezer coils froze up. It's an automatic defrost. I have found the coils and I think I know where the coil heater and the thermostat are.
Do I have to remove the floor of the freezer to replace the heater.
Is there a way for me to determine if it's the thermostat or the heater?
Thank you for your help.
Bobby
#2 Posted : Tuesday, May 18, 2010 2:07:35 AM(UTC)
Replacement parts for FRT22INLH models | AppliancePartsPros.com
Your model number looks short a couple digits.
Below I used the INLHB0 unit.
Defrost Timer is Item 23 in Section 3
Defrost Heater is Item 14 in Section 4
Defrost Thermostat is Item 21 in Section 4
You should only have to remove the back cover in the freezer to get at the heater and thermostat.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
