My Maytag model che9800 bcm range digital display has gone blank. It is a slide-in model (purchased April 1997), with the controls on the front end above the oven door. Pushing the keypad buttons does nothing. The cook-top burners and oven light works. The oven itself does not work. The circuit breaker for this outlet is not tripped. The oven element is intact (replaced 5 months ago). Is there an internal fuse for the control panel? If so where is it located? If not a fuse, is it a blown out circuit board? Would this be a difficult problem for me to repair? I'm experienced at soldering and replacing components on circuit boards. So, if were a bad capacitor I could replace it. Expensive? How do I access the control panel? I can't see how the glass cook-top is removed. Can you give me a step by step troubleshooting procedure to follow? Thanks, Ted-
My Maytag oven shut down while baking Christmas dinner. Gas burners and light still worked fine. After trying Sabbath fix (hold Clock button for 5 seconds), we called one of those guys who knows how to fix everything. His suggestion of unplugging it for one minute did the trick! Caution: my clock has been losing time lately, so this may not be the ultimate fix.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Control board will not work. Maytag Gemini double oven. Powers on. Is there a quick fix? A fuse?
Rank: Guest
Maytag model che9800bcm digital display is blank, if I push on top it comes back on, and last a day or 2 then out. How do I remove top to repair?
