You are welcome. I'm glad you were able to fix it.
Originally Posted by: DIYMrC  Thank you Gene for providing this repair information. I was able to use your instructions on my Frigidaire refrig that had the same ice build up at the defrost drain under the evaporator coils as well as on the bottom of the freezer. Hair dryer I would not have thought of it but it worked great. Thanks again! FYI, nearly a month later and all is fine.
