pictureman
#1 Posted : Wednesday, July 2, 2008 10:24:07 AM(UTC)
pictureman
My dishwasher is now leaking from under the door on both the left and right side at the bottom of the door, more so on the left. It will do this in wash and rinse cycles. Starts with a few drips, pauses, a large blop, stops, a few drips, then the big blop again. Isn't a flood, just the width of the machine and about 6-8 inches out on the tile floor at the end of it's job.
The seal, door edges and both "deflectors" (part 12 on the diagram) all appear to be non-dammaged and in place. I have raised and lowered the front levelers up and down from the original installed position by 1/4 inch and it makes no difference in the leak volume. Water temp is 130 or less.
Any suggestions?
Whirlpool dishwasher door leaking (Dishwasher Repair)
by R.E.BOB 9/22/2008 9:38:00 AM(UTC)
