gwfulton
#1 Posted : Friday, May 14, 2010 2:03:32 PM(UTC)
gwfulton
This dishwasher last night continually filled and drained all night, the only way to stop this was to turn off the water going to the dishwasher. Now if I turn on the water, it continually fills up and will not drain. Any thoughts on what this could be. I have vaccumed out the water, and checked the filters as well as the opening for the impeller for debris. No luck. Any help will be appreciated.
Thanks,
Garry
PaigeH4
#2 Posted : Tuesday, July 27, 2010 6:45:01 PM(UTC)
PaigeH4
Did you get an answer for this problem? I just bought and installed a Bosch and when I turn the water back on to try it out, the vent hold inside pours water into the tub. This is before I have begun to run a cycle. I am baffled.
Thanks.
gwfulton
#3 Posted : Wednesday, July 28, 2010 3:13:44 AM(UTC)
gwfulton
PaigeH4,
In my case the problem turned out to be the water inlet valve. After I replaced that the dishwasher is running normally. Hope this helps.
Garry
