Coils are freezing up I changed the timer and it will run two days then freeze up. The refrigerator is not as cool as it used to be. I cut timer to defrost and the heater cut in and melted the ice and it did shoot out some steam at the bottom of the coil. I turned the cooling nob on refrigerator up to 5 and still no cold air even when freezer is working.
you can activate the defrost cycle manually . make sure it defrosting if not that mayber your freon is low..
What is the complete model number of the refrigerator?
What is the part number of the new timer?
