Everything seems to work fine,It just started to humm after 1sec of hittin the start button.It will not heat now,but I only tried 30sec's a couple of times.Didn't want to mess anything else up...I can fix, just need help troubleshooting.THANKS MUCH.
only 4 parts involved.. 1. big transformer (since its humming probalby ok) 2. big diode.. (check with meter) 3 big cap. (check with meter) 4. magnetron.. (normally the only checks i know of it to verify that with a clamp on amp meter that there is around 8-12 amp going to the magnetron. also unplug and verify that the 2 terminals of the magnetron are not shorted to ground the case)
