I am trying to find the part where the water line attaches to the ice maker on the back of the freezer. It is leaking where the 1/4" tubing attaches when the ice maker calls for water. It appears to be a rubber right angle connector that has a clamp holding the 1/4" line to it but I can't find a part for it on any sites that has parts for this model. It doesn't appear to be broken, I cut a 1/2" off the tube and reinserted it thinking that that may be the problem, I also replaced the insert in the tube. Same problem. I am thinking of a small hose clamp but wanted to see if anyone out there has ever had a similar problem. Thanks JE
Originally Posted by: JE_inc  I am trying to find the part where the water line attaches to the ice maker on the back of the freezer. It is leaking where the 1/4" tubing attaches when the ice maker calls for water. It appears to be a rubber right angle connector that has a clamp holding the 1/4" line to it but I can't find a part for it on any sites that has parts for this model. It doesn't appear to be broken, I cut a 1/2" off the tube and reinserted it thinking that that may be the problem, I also replaced the insert in the tube. Same problem. I am thinking of a small hose clamp but wanted to see if anyone out there has ever had a similar problem. Thanks JE I just had this problem with my kenmore side by side, it was leaking water inside my freezer and freezing solid in the ice bin. I tried the same thing as you removing that tube and it didnt work. It turned out to be water valve that is in the rear of the fridge that your water line feeds into. And it opens and closes for the water going into the ice maker and when it goes bad it overflows .There is also a filter in it that you can clean..I just replaced it and it solved my problem.
