oklabull
#1 Posted : Thursday, May 13, 2010 5:02:19 AM(UTC)
oklabull
Timer won't advance from automatic drying settings. Dryer will heat up just wont shut off. Timer will advance from timed dryer settings just not the automatic settings. any suggestions?
ApplianceJunk
#2 Posted : Thursday, May 13, 2010 7:24:13 AM(UTC)
ApplianceJunk
Clean and check your vent for kinks.
Also check inside the blower housing for lint build up.
Even if it "feels ok" when you check the vent for air flow with your hand you need to look inside the vent and inside the blower houseing for lint build up.
