paisleymrs
#1 Posted : Thursday, May 13, 2010 3:39:43 AM(UTC)
paisleymrs
Hello My Panasonic Inverter Microwave makes a buzzing sound when not in use? It works just fine but the buzzing is concerning me... Had it for about 2 years and the buzzing started almost immediately. It seems to be more frequent now. Please advise if it should be fixed or replaced.
Thank you:confused:
#2 Posted : Thursday, May 13, 2010 10:43:13 AM(UTC)
Thank you:confused:
Unfortunately there is no any technical information available on line for Panasonic products.
tvtech
#3 Posted : Friday, May 14, 2010 10:58:54 AM(UTC)
tvtech
There is probably a winding loose in one of the transformers wont hurt anything.. u can use a long tube and put it to your ear to verify which transformer is noisy.. then try some silicone apply small amounts as it will also insulate the windings making more heat.
