fishnlord
#1 Posted : Monday, June 30, 2008 8:03:09 PM(UTC)
fishnlord
My freezer side of the fridge recently started freezing up inside right above the ice chute. It is due to the door to the ice maker chute being broken loose. I am trying to figure out how to access it. The front panel appears as though it might "pop" off, but, I'm hesitant to try that. Does it just pop off or am I overlooking some screws that loosen the front panel? Thanks for any help!!
#2 Posted : Tuesday, July 1, 2008 7:50:59 PM(UTC)
The front cover can be removed by inserting a small flat screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed.
- The part number for the ice dispenser chute door is AP3601811
ice maker broken (Refrigerator & Freezer Repair)
by eileenb1234 6/23/2008 1:00:52 PM(UTC)
Whirlpool ice maker broken (Refrigerator & Freezer Repair)
by jbrown9999 5/28/2008 12:24:06 PM(UTC)
