neely732
#1 Posted : Tuesday, May 11, 2010 4:09:49 PM(UTC)
neely732
Our washer won't spin it will only spin when it is washing not on the spin cycle. I was wondering what part number to buy? And the error code is E47. Which I believe means a new door lock. If so how do I install?
#2 Posted : Tuesday, May 11, 2010 6:29:02 PM(UTC)
The "E47" error code means "Board thinks the door PTC circuit is open in spin". Remove the door lock and check the resistance of the PTC. It suppose to be around 1500 Ohms. If the reading is correct, replace the control board.
- The door lock Part number: AP4455026
Machine won't spin - makes loud noise (Washer Repair)
by lpcon 7/18/2014 4:36:22 PM(UTC)
Washing machine won't spin (Washer Repair)
by Mjbruner1 10/3/2013 1:33:04 PM(UTC)
Washing Machine won't spin out water (Washer Repair)
by dlong55 9/29/2013 6:45:30 PM(UTC)
Washing machine won't spin or drain after rinse cycle (Washer Repair)
by brodyn 2/19/2013 7:45:13 PM(UTC)
frigidaire flse72gcs7 gallery laundry center washing machine won't spin (Washer Repair)
by hyperturtle 1/14/2013 8:18:44 PM(UTC)
by watertoy321 4/25/2012 11:29:09 AM(UTC)
by Monty Wyne 8/2/2011 11:13:08 AM(UTC)
Washing Machine won't spin (Washer Repair)
by golfer63 6/5/2011 9:03:36 AM(UTC)
Washing Machine won't spin only tries (Washer Repair)
by tferguson1970 5/23/2011 8:25:23 AM(UTC)
washer machine won't spin (Washer Repair)
by elbebe2525 1/6/2010 10:59:58 AM(UTC)
by telesa 11/2/2009 9:51:52 AM(UTC)
by kathy ouellette 7/12/2009 10:25:11 AM(UTC)
by stevecook 6/24/2009 2:09:23 PM(UTC)
hotpoint washing machine won't spin with clothes (Dishwasher Repair)
by Wayne Thomas 5/26/2009 8:03:37 AM(UTC)
washing machine won't spin the water out it (Washer Repair)
by jgosch 5/9/2009 10:58:46 AM(UTC)
