I'm trying to replace the oven ignitor but can't get oven bottom out, I removed the two screws in the back of the oven bottom and I can get it to pivot forward but that's it. Any secret to getting it out?
Lift the back of the oven bottom and slide it outward to release the front of the oven bottom from the frame and then remove it.
Thanks Gene, that did the trick
