My washer does not stop filling. Can anyone tell me the name of the part I need to order to fix this problem? Thank you.
How did you get the water to stop? Did you turn the water off or did you pull the knob to stop the timer or did you unplug the electrical cord? 1. If you turned the water off, it could be several things, Water Level switch, Water Temperature Switch, Inlet solenoid valve or the Timer 2. If, you pulled the plug or the power off knob and the water continued to run then the water inlet solenoid valve is the culprit but there is the possibility of multiple components
