Well i did some investigation why the frig part was getting warm. I opened up the panels from inside the freezer. There's a build up of frost all over the coils.
I looked at the defrost heater kit that rests at the bottom of the coil. The inside of it is somewhat black? Does that mean it's burnt out and needs replaced? I'm not sure how to check continuity on this.
Any help would be appreciated. Thanks
Jim
Discoloration is a sign of a burnt out heater. The replacement now comes with two elements in the assembly for more effeciency. Part number: AP4355467
Originally Posted by: magician59  Discoloration is a sign of a burnt out heater. The replacement now comes with two elements in the assembly for more effeciency. Part number: AP4355467
Awesome thanks. The one i have is single element. I'm going to go ahead and order it. Thanks, just wanted to be sure. So i need to thaw out the frost that's on the coils before i installed the new one right?
Another quick question regarding this. Is it possible to have a bad thermostat and defrost heat at the same time? I can't locate the thermostat.
Should i go ahead and order a new thermostat as well?
Just replaced thermostat and defrost heater kit! Working like new. Shipping was amazingly fast.
Thanks a ton Magician!!
You saved a ton of money on the service call...well done!
