mmich187
#1 Posted : Monday, June 30, 2008 2:45:38 AM(UTC)
mmich187
Hi there,
My washer starting squeeking a few weeks ago on the rince cycle.
I tool the cover off and noticed the idler pulley was frozen..
I oerdered a new one with the belt.
Do I need to lubricate the pulley shaft when replacing or is it self lubrication.
#2 Posted : Monday, June 30, 2008 2:08:27 PM(UTC)
If the shaft is rusted, it's better to replace it too. If it's not then small amount of grease would not make it worse.
