phild
#1 Posted : Saturday, June 28, 2008 7:24:47 PM(UTC)
phild
How is the clutch assembly removed? Once clip is removed, the clutch assembly does not come off. How hard is it to replace the clutch?
abadfish66
#2 Posted : Saturday, June 28, 2008 8:19:48 PM(UTC)
abadfish66
Once the clip is removed, it is removed by pulling it straight off the shaft, sometimes they are really stuck and need to be pryed off, using a screwdriver will help pry it off.
clutch removal (Washer Repair)
by thelazydentist 12/3/2007 12:33:22 PM(UTC)
