The plug for the microwave in this built in oven pulled out and shorted the power supply to the microwave only. It there a replacement fuse or circuit breaker which can be replaced?
i have a thermadore and it has a separte fuse . mine was located on the top of the unit towards the back as big as your thumb hard to miss. follow the power wire. (most time fuse blows cause of metal in the oven.)
