TeddyTech
#1 Posted : Friday, May 7, 2010 6:22:07 PM(UTC)
TeddyTech
Hi...
I have a Whirlpool Gold double oven (GBD307PDB7). There is a vent just above each door where moisture is vented out. On the lower oven it seems like a fan is forcing the air into the room.
The problem is on the upper oven. The moisture just rises from this vent ... right up the front of the wooden cabinets above. It seems that there must be a fan somewhere that should be forcing this moisture more out into the room.
I have found the blower fan, but this ducting for this vent does not seem to be connected to the blower fan. (However, this blower fan does not seem to be running when the oven is on so maybe it is my problem. I am not sure of the purpose of this fan.)
Thank for any help!
Teddy
