rturner
#1 Posted : Saturday, June 28, 2008 6:02:41 AM(UTC)
rturner
PLEASE!!!!!! I NEED HELP NOW!!!!!!!!!when I push the start button the dryer drum will not spin. The heater turns on but thats it, WHAT COULD IT BE????????????? HELP!!!!!!!!
#2 Posted : Sunday, June 29, 2008 9:17:48 AM(UTC)
If the motor fails to run, it could be your thermal fuse mounted on the blower housing, a thin white item. If the heater comes on without the motor running, you probably have a bad motor centrifical switch.
Does the motor make any noise when you try to start it?
