jhays1211
#1 Posted : Thursday, May 6, 2010 10:48:09 AM(UTC)
jhays1211
i need step by step instructions on the best way to disassemble my washer. It is leaking from the front.
Kanza
#2 Posted : Thursday, May 6, 2010 7:11:54 PM(UTC)
Kanza
Locate two screws, one in each bottom corner of control console on back. remove screws, pull console forward then up and flip over backwards. disconnect wire harness going from console to cabinet. locate two gold clips, one in each corner of cabinet. Put screw driver down in clip and pry towards back, clip will pop loose from cabinet. remove clip, repeat on other side. Tip cabinet towards you and pull out, cabinet will slide out from machine. reply with ?s
