No power to icemaker. Closed flapper door and door switch, red LED light goes out; still no power. Light blinks when flapper is open. Seems like a bad reciever/emitter board. Any ideas??
Rich, Close the flapper door but do not touch the light switch. Watch the LED. If it blinks, the optics have gone bad. If it stays On but there is still no power at the ice maker plug, check for incoming 120 VAC (the white and black wires at the emitter board) and if it's fine, outgoing 120 VAC (the white/black and white wires at the receiver board). Here is the Tech sheet. Gene.
Thank's Gene, the light blinks when the flapper is closed, will order the optics boards, not a bad price either.
