I ordered part #74011243 burner swith for my caloric stove burner, but the part I received has seven prongs in the back. The part I removed only has five. First is this the right replacement part, and if so how should I reconnect (which five prongs to be used)? #P11 ??477N-W #9504289081
Old terminals one P, one L1, one L2, one H1, and one H2.
New terminals one L1, two L2 joined together at the base, one H1,one H2,one P2, one unmarked, and a quarter of an unmarked terminal.
Part #7450P020-60 or #50.59079.094 This part is the one in the diagram! #74011243
Originally Posted by: curtco  Old terminals one P, one L1, one L2, one H1, and one H2.
Part #7450P020-60 or #50.59079.094 This part is the one in the diagram! #74011243 L1 old = L1 new, L2 old = joined L2 new, H1 old = H1 new, H2 old = H2 new, P old = P2 new. Gene.
Thanks Gene the burner is working just fine!! Curt
You are welcome Curt. I'm glad you were able to fix it.
