mikerozell
#1 Posted : Tuesday, May 4, 2010 6:58:39 AM(UTC)
mikerozell
the turn table turns constantly (ie when i open the door it is still turning, when i shut the door it goes off. it does turn when i turn it on)
i have been told to replace the door switch, but cannot find the right one. i haven't taken it apart....YET!
#2 Posted : Tuesday, May 4, 2010 12:02:29 PM(UTC)
Most likely the problem is a bad upper door (interlock or sensing) switch (#26 on the diagram).
- The door switch Part number: AP2024337
