i have a beep that is coming from the control panel in the fridge side of my frigidaire side by side. it beeps 4 or 5 times then stops and then starts again about every 10mins or so. also i set the control to 9 for both freezer and fridge but after a few seconds the fridge control changes to a flashing 4. any idea what is causing these problems
Unfortunately there is no Service manuals for this model available on line. You probably have to call an authorized service to diagnose this problem.
thanks so much for the info you have saved me no telling how much time searching for a repair manual. your expertise and time is greatly appreciated. thanks again, Farris.
