My washer leaks from underneath it when ever I run it. Not a lot but I bought a washer plastic floor containment to go under it from Lowes because otherwise it does make a mess around it. I raised it up on blocks to see if I could find the leak while it was running but all I could see is sort of a drip coming from maybe around the front part of it. Please help me keep peace in my family (from my wife). Like I say it still works but it leaks.
Most likely the problem is a bad pump which should be replaced. Remove the cabinet and proceed according to these instructions. - The part number for the pump is AP2907492 Gene.
Abqaiqmike
(Washer Repair)
by abqaiqmike
6/25/2008 2:51:41 PM(UTC)
