GeneMcElroy
#1 Posted : Monday, May 3, 2010 6:36:39 PM(UTC)
GeneMcElroy
My grandaughter pressed the START button instead of the TIMER button. The time was for 12 minutes. At some time after the microwave started it went dead. I believe that the thermal fuse may have blown. I don't know where the fuse is located or how to dismantle the microwave to replace the fuse. Please help.:o
tvtech
#2 Posted : Friday, May 14, 2010 11:24:26 AM(UTC)
tvtech
open unit there will be screws... lol then follow power wire to find fuse
#3 Posted : Friday, May 14, 2010 3:51:01 PM(UTC)
The problem can be a bad cavity thermal fuse (#5 on the diagram) or in-line fuse (#28 on the diagram).
You can find the wiring diagram and parts layout in the Tech sheet.
- The cavity thermal fuse Part number: AP3038827
- The in-line fuse Part number: AP4308182
Guest (4)
My dryer all of a sudden does not work at all (Dryer Repair)
by mpgarcia6969@gmail.com 8/28/2016 9:12:33 PM(UTC)
Maytag Washer does not work at all (Washer Repair)
by kangg 11/2/2009 12:12:52 PM(UTC)
Does Not Work At All.nothing Comes On (Washer Repair)
by cordell 8/2/2009 7:46:24 AM(UTC)
