tooclean
#1 Posted : Monday, June 23, 2008 5:24:14 PM(UTC)
tooclean
After a lighting storm ref stopped No display,nofans,no compressor.
Is this a motherboard problem?
Do I need to also replace evap fan motor?
abadfish66
#2 Posted : Monday, June 23, 2008 9:00:58 PM(UTC)
abadfish66
Did you check you breaker to see if it was tripped? Plug something else in that socket to make sure it works, then Pull the refer out from the wall, and take the cover off at the top left, remove the board and look for burn marks....Keep us posted
