Model GSL25 JFTC BS-Every morning is appears the defrost has kicked on and everything in the freezer is wet or has been wet and freezing up again, Ice has thawed because it is in a huge frozen clump now. Is something with the defrost going crazy??? Thanks in advance for any help.:confused:
A model number may help others help you. I am assuming that everything else with the unit seems OK. Sometimes an intermittent/sticking main thermostat can cause this. It could be the defrost thermostat. This is clipped onto the evaporator coils. The defrost cycle is usually a set time but when all the ice/frost is melted off the coils the thermostat opens and cuts power to the defrost heater. Check that it is infinite ohms (open) just above freezing. Also if it looks bulged it needs replacing. Here are a couple good sites with basic fridge troubleshooting/repair info. http://www.applianceaid.com/frig.html Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com |
THIS FORUM IS DEAD!!!!!!! |
