GE dishwasher will not let water fill.if you put water in yourself it will spray. and wash but as soon as the water has pumped out it will not rinse.
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Check the water valve ( #744 on this diagram). The solenoid might be bad, in which case replace the valve. Or the screen inside the valve may be clogged, clean it.
