dwartz
#1 Posted : Monday, June 23, 2008 7:05:10 AM(UTC)
dwartz
"Oven" and "Heating" blue LEDs alternate flashing 2 X's each. Large oven not working. Small oven's LED's were doing same but reset circuit breaker and small oven started working. Any ideas? Figure it's a circuit Bd but need disassembly instruction. Appreciate any help
#2 Posted : Monday, June 23, 2008 9:21:17 PM(UTC)
The Oven blue light flashing two times, followed by the Heating blue light flashing two times means the "22" or "E1" error code and the correction is to replace the electronic control board.
The electronic control board is located at the back lower left side of the oven. You have to pull out the range to gain access to rear of the unit.
- The part number for the electronic control board is AP3891182
