scstamps@live.com
#1 Posted : Sunday, June 22, 2008 1:18:39 PM(UTC)
scstamps@live.com
micro makes buzzing noise when turned on. seems to be comming from part called the stirrer. also starts running when you partily open top door latch.
#2 Posted : Monday, June 23, 2008 11:46:04 AM(UTC)
Does it heat?
scstamps@live.com
#3 Posted : Monday, June 23, 2008 1:01:51 PM(UTC)
scstamps@live.com
yes it does.
#4 Posted : Monday, June 23, 2008 6:16:11 PM(UTC)
Looks like there are two separate problems: the stirrer motor behind the top grill) and the interlock door switch (inside the control compartment on the door frame).
- The part number for the stirrer motor is AP2151223
- The part number for the interlock switch is AP2151217
