the door gasket surrounding the door is very hot. Any suggestions on what may be the problem?
You have been a member since:: 5/28/2008(UTC) Posts: 1,620
Your condensor needs to be cleaned, if it's clean, check your condensor fan to make sure it's running. Those are the 2 reasons for the heat.
