Dryer is not heating although heating element is okay. What are type of troubleshopoting should I apply?
You will need a meter to check things.
Check the dryer duct where it vent to the outside,turn on the dryer on normal,go outside to where the lint comes out,there should be a strong flow of hot air coming out,if there is just a trickle or no hot air coming out you have a blockage,this is usually caused by lint building up,or by birds building their nest in the vent,clean with a vacuum and or lint brush. clothes dryer vent on Yahoo! Video
