I have a couple numbers on my control panel which are inop. Can someone advise me how to remove the control panel on this model ?? I have some spray contact cleaner which I will try first. I'm assuming the panel is attached via a ribbon connector. My next step would be to clean those contacts. If that does not solve the problem any suggestions to repair the pad before ordering another ??
You need to remove the top vent grille, should be 2-3 screws on top holding it on. Once you remove the grille, you will see 1 screw holding the control panel on
