I have researched and determined the error code I am receiving is either the thermal fuse or temperature indicator. (F3 E0)I have looked at the diagrams that I could find online, but I cannot find the fuse in the control panel of my oven. I can't find a picture of what is should look like or where it is exactly in the control panel. I see it indicated in the diagram, but not where it is? Please help.
Without seeing a schematic, the most likely place to put a thermal fuse on an oven is either on the back of the oven behind a cover, or the first place I would look is under the cooktop, somewhere around the vent tube or such. It will be a round device with 2 wires attached may or maynot be a resetable button on it....
