The defrost water is leaking on to the fllor in front of the refrigerator fresh food side. The drain pipe (item 317) is clean. Seems like it is comming from the bottom of evaporator. GE tech said part #WR85X10088 needs replacing. Can you send me the instructions for replacing this part.
Also I noticed brown tape at the bottom side of the evaporator assembly from where water seeps out. Is it supposed to be like this.
Groups: Expert
Often times when a fridge has a water drip as you describe, the cause is simply a clogged defrost drain. Nothing is broken, just clogged. Depending on what this is clogged with you may or may not be able to easily perform this type of refrigerator repair. If its clogged with ice, and not food debris, unplugging unit, opening both doors, and blowing fan for 12 hours at freezer will result in a fix. If the bottom of your freezer builds with ice that again leaks onto kitchen floor, the food debris inside the tubing needs to be cleared out by a repair service.
The leakage or the water drip is not from ice or clogged drain by food. The drain pipe is clean. The water is dripping from under the evaporator coil through the inside of food compartment on to refrigerator floor and then through the door bottom on to the kitchen floor.
Groups: Expert
It is extremely hard if not nearly impossible for defrost melt water to travel from the evaporator located above the freezer section to the floor of the refrigerator. I checked three different sources and none show an image of this evaporator case support, the part that GE tech said you required. However, assuming it supports the evaporator coil as the name implies, and knowing how difficult this model is to work with even for an expert refrigerator repair service, I would highly recommend you call around for local services to have someone at least inspect and diagnose your unusual problem.
I have a very similar (if not identical) problem. FridgeDoctor didn't READ your post and doesn't know what he's talking about! How did you solve the problem? Thanks for your help. rick.stouse@gmail.com
