Replaced ice maker as the motor was shot. Installed new ice maker but have no ice after 48 hours. Emitter and receiver check out okay, as does inlet valve. Tried to initiate harvest cycle by jumping T and H, but nothing happens. This same thing happened with another fridge a couple of months ago. What am I missing???
Groups: Expert
Well, the problem could lie within those optic boards, despite passing an optic test. That only means the optics are good, not necessarily the boards. Plus, depending on the year of your model, your fill tube could have been frozen, due to a design flaw. You can check this by pulling fridge out, marking the top of the cabinet with the entry point of the water line near the top, middle portion behind the unit. if it enters within the fresh food side of the divider wall in front, you should be ok as far as the water line freezing, but you probably have to replace your optic boards, if it enters within the freezer side, that fact may be the cause of your problem, and you need to install a fill tube heater. I can help you with your refrigerator repair if you live in Chicago or Chicago Suburbs if you decide you want expert help.
Originally Posted by: FridgeDoctor  Well, the problem could lie within those optic boards, despite passing an optic test. That only means the optics are good, not necessarily the boards. Plus, depending on the year of your model, your fill tube could have been frozen, due to a design flaw. You can check this by pulling fridge out, marking the top of the cabinet with the entry point of the water line near the top, middle portion behind the unit. if it enters within the fresh food side of the divider wall in front, you should be ok as far as the water line freezing, but you probably have to replace your optic boards, if it enters within the freezer side, that fact may be the cause of your problem, and you need to install a fill tube heater. I can help you with your refrigerator repair if you live in Chicago or Chicago Suburbs if you decide you want expert help. Thanks for your quick reply. I went and got the 2 boards and replaced them both. Nothing changed. This is also not a 'frozen line' problem. I put water in the ice tray itself. Now there are ice cubes in the tray which never harvest. This evening I jumped "T" and "H" and the dial would not spin. Is there anything else I can do?
Groups: Expert
be patient. leave it alone for 24 hours.
