busch
#1 Posted : Saturday, April 24, 2010 1:52:17 PM(UTC)
busch
Hello,
My washer wil fill with water and will attempt to start the agitate cycle.
I removed belt and checked transmision which is fine.
with the belt removed the motor will start then imediately stop.
No contact on the motor ohms to ground all seems fine on it.
Now im familiar with hvac and refrigeration but never have seen much action on washer timers and motors.
The washer will spin out just fine. This does not seem like motor protection causing the issue but i may be wrong. Any help to light my way is greatly apreciated
busch
#2 Posted : Wednesday, April 28, 2010 10:23:32 AM(UTC)
busch
allright i found that the motor is going out on overload protection in delicate cycle but will agitate on other cycles. i suspect the timer control.
#3 Posted : Wednesday, April 28, 2010 2:28:44 PM(UTC)
This is a two speed motor and, more likely, the problem is a bad low speed motor winding.
- The motor Part number: AP4024680
Here are the breakdown diagrams and Replacement parts for CROSLEY CW6000W Washer - Top Loading | AppliancePartsPros.com
P.S. I'm assuming you missed one zero in the model number.
Motor or control (Washer Repair)
by joep189 12/27/2010 6:11:09 AM(UTC)
Diagnosis Of motor or controler (Washer Repair)
by ceesranch 8/20/2009 4:25:12 PM(UTC)
