freezer wont defrost /just replaced heat defroster or what ever u call it/ how do i adjust timer/ i think it runs to long per cycle.PLEASE HELP .YOU CAN CALL ME OR EMAIL--FAST . BRUCE chessmann@verizon.net /443-813-0720
Originally Posted by: chessmann  freezer wont defrost /just replaced heat defroster or what ever u call it/ how do i adjust timer/ i think it runs to long per cycle.PLEASE HELP .YOU CAN CALL ME OR EMAIL--FAST . BRUCE chessmann@verizon.net /443-813-0720 please reply fast
Originally Posted by: chessmann  please reply fast pleas reply soon waiting
somebody reply i/am new to this maybe i/am doing it wrong
Groups: Expert
I will try and help you with your refrigerator repair. Since you replaced the defrost heater assembly, that which actually heats up, I would further check your defrost termination limit control, clipped to the top of the evaporator, and if that is ok, then your problem will be with the defrost control, failing to switch unit into defrost cycle.
