Vette
#1 Posted : Wednesday, June 18, 2008 7:12:10 AM(UTC)
Vette
My Maytag washer overfills in both the wash cycle and rinse cycle. The problem seems to be intermittent. I have replaced both the pressure switch and the air hose going to the switch and it has not solved the problem. What else could it be?
#2 Posted : Wednesday, June 18, 2008 7:48:02 PM(UTC)
It could happen if the water inlet valve stuck open.
- The part number for the water inlet valve is AP250067
Here are the break down diagrams for the Maytag washer Model LAT9334AAL
Vette
#3 Posted : Thursday, June 19, 2008 7:17:32 AM(UTC)
Vette
Thanks Gene. That fixed my problem.
Paul Heinevetter (Oven Repair (including Ranges and Cooktops))
by Paul Heinevetter 7/21/2010 10:45:17 AM(UTC)
