tenneco
#1 Posted : Thursday, April 22, 2010 8:33:54 AM(UTC)
tenneco
The door seal area between the doors on a side by side is getting hot. Seems to be hottest when the refrig is opened frequently.
Any help in what is needed to correct this issue is appreciated.
Thanks!
#2 Posted : Thursday, April 22, 2010 8:44:27 AM(UTC)
Often this is just dirty condenser coils.
See the link below #18
http://www.applianceaid.com/refrigerator.html
Also check that the condenser fan is running.
The way I clean mine is to remove the kick plate and the lower rear cover.
I then roll it over to the open kitchen door and blow it out with my compressor, most of the dust ends up outside. Also a leaf blower works.
This may not be possible for you inwhich cae a vacuum and a brush works.
They do make special long brushes just for this job.
Also clean the fan and it's blades.
tenneco
#3 Posted : Thursday, April 22, 2010 8:49:02 AM(UTC)
tenneco
Thanks, I will give it a try. I was thinking that there were heat strips in the door seal areas to prevent condensation, and maybe that circuit was staying on.
Thanks again for your response.
#4 Posted : Thursday, April 22, 2010 9:55:13 AM(UTC)
Some units do have a similar set up but there is usually an energy saver or econo switch on the control pane to shur this off.
tenneco
#5 Posted : Friday, April 23, 2010 9:17:34 AM(UTC)
tenneco
I took your advise and cleaned the coils and the probelm has been solved.
Many thank for yur excellent advise. I am sure I will be in contact with you soon to discuss another Whirlpool referigerator that has an ice maker that has stopped working.
Thanks again!
