2 Pages12>
BOBNY
#1 Posted : Thursday, April 22, 2010 7:55:04 AM(UTC)
BOBNY
RECEIVED PART WB27X10311 WITH TO8-2K CONTROL REPLACEMENT FOR TO8C. WIRING DIAGRAM FOR TO8-2K NOT CLOSE TO TO8C.
TO8C HAS 2 RED WIRES ON 1 TERMINAL
1 BEIGE WIRE AND A BEIGE AND WHITE WIRE 1 TERMINAL, BOTH TERMINALS ON A COMMON TERMINAL ON BOARD
1 BLUE WIRE ON SEPERATE TERMINAL
1 YELLOW WIRE ON SEPERATE TERMINAL
NO PURPLE WIRE
noreenbob7@optonline.net
#2 Posted : Thursday, April 22, 2010 4:00:26 PM(UTC)
Can you post a picture of the old control board with all terminals and wires shown?
BOBNY
#3 Posted : Friday, April 23, 2010 8:44:14 AM(UTC)
BOBNY
How do I attach a sketch I drew, or is there a way i can fax it to you.
Thanks again, BOBNY
BOBNY
#4 Posted : Thursday, April 29, 2010 7:11:39 AM(UTC)
BOBNY
Hi Gene,
I responded to your email instructions to askgene.gmail.com with another sketch with my understanding of your instructions.
Just a thought. Should the 2 red wires, which are common on the TO8C board, go together on the Broil relay and the white and 2 beige, which are common on the TO8C, board all go to the AC N terminal (the only terminal on the T08-2K board)
Hopeing for your response,
Thanks again,
Bob
#5 Posted : Thursday, April 29, 2010 2:06:18 PM(UTC)
Hi Bob,
I've been thinking about this strange configuration and looks like you are right. Connect both Red wires to the Broil relay COM terminal and the White & both Beige wires to the neutral terminal.
BOBNY
#6 Posted : Monday, May 3, 2010 8:16:38 AM(UTC)
BOBNY
Hi Gene, :D
Replaced the T08C with the T08-2K per your instructions this morning.
SUCCESS. All functions, bake, broil, range elements etc. appear to be working.
Thanks again for your responses and help.
I and my wife thank you,
Noreen and Bob :)
#7 Posted : Monday, May 3, 2010 5:53:02 PM(UTC)
Noreen and Bob,
You are very welcome. I'm glad you were able to fix it.
cgor2000
#8 Posted : Wednesday, January 26, 2011 7:24:10 AM(UTC)
cgor2000
Question, I have an GE Range model JBP 45A S1AD Ser# LH206633G Date build
June 1993. My Control TO8c # PS240130, i think is bad would the Range Control Substitute To8-2k For To8c work for me? Thanks, chuck
#9 Posted : Wednesday, January 26, 2011 12:03:55 PM(UTC)
Hi Chuck,
The ERC for the model number you posted comes up as no longer available and there are no any substitutes comes up in the searches I've ran.
You can try to use it but the result is unpredictable.
cgor2000
#10 Posted : Wednesday, January 26, 2011 12:31:08 PM(UTC)
cgor2000
Thanks, chuck
2 Pages12>
