magic
#1 Posted : Tuesday, June 17, 2008 8:51:33 PM(UTC)
magic
Water siphons out during rinse cycle, pump not running. Noticed washer motor got hot. The drain stand pipe is at 33", drain hose loop up at 48"
some times it works O K. I removed agitator and cleaned filter. This is a stacked unit with dryer on top. It worked fine since new in the same location. I also checked all the electrical connections , and they looked fine.
#2 Posted : Wednesday, June 18, 2008 6:46:01 PM(UTC)
Did it try to spin during the agitation?
magic
#3 Posted : Thursday, June 19, 2008 8:07:07 PM(UTC)
magic
did not try to spin in rinse cycle. I have a 40' drain hose outside on a good down hill slant. I disconected half of it and rinse cycle is working fine now.
this is an odd problem, could it be that the hose has enough friction or suchon. or is it just a temporary decided to work O K. I flushed drain hose with pressure fom garden hose????
washer rinse cycle problem (Washer Repair)
by amy s 12/1/2010 3:01:22 AM(UTC)
GE Profile Washer Rinse Cycle problem (Washer Repair)
by bwhitsett 10/8/2009 12:15:18 PM(UTC)
