Welcome Guest! To enable all features please Login or Registers.
tessiepell
#1 Posted : Thursday, April 22, 2010 5:59:43 AM(UTC)
tessiepell
Morning. for the past 3 weeks my dryer started to squeek when turned on. It starts out loud in the beginning but eventually gets lower when it is running for a while. I read some forums and decided to change the bearings. I purchased a bearing kit AP2619300 and installed it over the weekend. When I first used the dryer after the new bearing was installed it was fine, now after 2-3 loads it is squeeking again. I did some more research and now it says to change the Dryer drum slide AP2041815 & AP631382. Do you agree? If so, how many should I order & what colors? It recommends to change as a set! Any other suggestions you may recommend? Thanks Jerry jtatonetti@aol.com
kayakcrzy
#2 Posted : Friday, April 23, 2010 3:59:04 AM(UTC)
kayakcrzy
Replace all four. They are cheap and easy to replace. Tom ApplianceEducator.com - Parts
tessiepell
#3 Posted : Friday, April 23, 2010 5:56:27 AM(UTC)
tessiepell
Hi Tom, When you say replace all 4 what exactly am I going to order? 2 of AP2041815 & 2 of AP631382? Thanks Jerry
