I was having problems getting water to drain after the washer went through entire cycle. Now, the door is locked......no controls work, it just says door locked. I tried unplugging and leaving overnite but when plugged back in it is the same. Help I have a load of clothes washed sitting in the washer - yuck.
To manually unlock the door remove the bottom panel first. Reach behind and up the right side of the front panel, pull the release ring down, then open the door.
