js109866
#1 Posted : Tuesday, June 17, 2008 10:57:46 AM(UTC)
js109866
I have an ERR uo display code. According to the Service Data sheet it is a "Vent will not close" error... I have run the dishwasher through the Water/Service Test and it fails on step 8 with a Detection Error code of RA. Components verified during step 8 Drain Motor and Fan. I believe that I have an issue with the vent Assembly/blower unit part number 154562802.. How do I test the vent assembly unit to verify that it is the defective part and not something wrong with the Electronic Control Board?
My dishwasher does work fine as long as I don't use the HI-TEMP or SANTITIZE options which will requires fan venting.
mark0978
#2 Posted : Friday, July 17, 2009 5:49:51 AM(UTC)
mark0978
Anyone out there know to fix this?
