JOSEPH RUBANO
#1 Posted : Wednesday, April 21, 2010 11:51:51 AM(UTC)
JOSEPH RUBANO
This stove is totally not working -- it stop suddenly a few days ago. I have checked and it is plugged in and all the circuit breakers are fine. I am wondering what would go on the stove that would cause this. Nothing works -- no lights, no heat,nothing.
If you have an idea what it could be could you give me the parts numbers.
Thank you for any help you can give.
Joseph
#2 Posted : Wednesday, April 21, 2010 3:19:42 PM(UTC)
Joseph,
This is electric range and if it's totally dead, most likely the problem is incoming power.
If it has a plug, unplug it and check for 240 VAC at the wall outlet (each hot leg to neutral should read 120 VAC).
If it's hardwired, call an electrician to check the circuit breakers and the range connection at the junction box.
Here are the breakdown diagrams and Replacement parts for General Electric RB526C3WW Electric range | AppliancePartsPros.com
JOSEPH RUBANO
#3 Posted : Wednesday, April 21, 2010 4:23:52 PM(UTC)
JOSEPH RUBANO
Thanks Gene -- I will check things out or relay the information to my friend so that he can have someone check it out and then I will take the step. If I need you again I will be in touch.
Thanks -- Joseph
